Date/Time: Mon, 25 Nov 2024 02:43:26 +0000
Number bars messed up[
View Count: 175
[2024-04-03 20:55:40] |
WeeksoOo - Posts: 3 |
I use the same studies for my charts but as you can see (in the attached files)one chart is normal and the other chart is messed up, how do I fix this?
Attachment Deleted. |
[2024-04-03 21:20:25] |
The main difference between these charts is scaling. Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
