Date/Time: Wed, 27 Nov 2024 06:32:33 +0000
Volume Value Aera Lines
View Count: 964
[2014-08-13 11:25:14] |
User14443 - Posts: 6 |
Hi, I use Volume Value Aera Lines in daily charts. I'd like to encompass sometimes 2, 3, 4 or more months in the same drawing. But when I use 3 as Time Periode Length, it doen't work (got 2 instead : August & July). Same thing using 5. The paramaters I use are as follows : Draw Developing Value Aera Lines...................Yes Ticks Per Volume Bar...............................4 Time Period Type...................................Months Time Period Length.................................Issue Automatically Correct Invalid Time Period Type......Yes Volume Value Aera %.................................0.68 Reference n Periods Back............................0 New Period at Day Session Start.....................No Use Day Session Only................................No Thanks a lot, Regards, Ralph. |
[2014-08-13 16:24:05] |
What you want to do is a single period at the end of the chart of 3 months long or you want to start it from a particular Date. Neither of these are supported with the Volume Value Area Lines study, but they are supported with the Volume by Price study: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 16:24:29
