Date/Time: Fri, 10 May 2024 01:18:59 +0000
Market Depth Historical Graph not updating in real time.
View Count: 96
[2024-04-03 16:15:15] |
User414556 - Posts: 2 |
Hello , I'm using Market Depth Historical Graph with package 11 - Integrated Advenced . My problem is my chard isn't updating live with new historical data. I have to right click and select Download depth data to update a chart. Please see screen below: https://www.sierrachart.com/image.php?Image=1712160721219.png The vertical red dashed line shows the time of the last manual forced download of historical data. I have tried all the options indicated in various threads on the forum but unfortunately nothing helps. Could you please advise? |
[2024-04-03 17:10:25] |
John - SC Support - Posts: 31509 |
You are not setup to get the Market Depth data as you do not have any exchanges active that include the Market Depth data. Therefore, the only Market Depth data you can access is the Historical Market Depth data we have. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-03 17:28:11] |
Thank you for your advice. I don't know how I could have overlooked something so obvious. Best Damian |
