Date/Time: Fri, 10 May 2024 18:17:09 +0000
How fast are Market of Touched orders?
View Count: 89
[2024-04-03 11:25:53] |
oceanzhang - Posts: 3 |
Are MIT orders sent to the exchange where they'll wait to be triggered? Or are they held on the Sierra platform and sent to the exchange after they're triggered? Lastly, are MIT orders even supported by CME? Thanks! Date Time Of Last Edit: 2024-04-03 11:30:30
[2024-04-03 16:57:36] |
John - SC Support - Posts: 31530 |
MIT orders are NOT supported by the CME Group. Therefore, MIT orders are held on your local Sierra Chart and transmitted when they are touched as a Market Order. The speed of the order depends on where you are located and what order routing service you are using. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
