Date/Time: Sat, 11 May 2024 21:59:22 +0000
Session Profile Start Time not Working
View Count: 83
[2024-04-02 22:46:06] |
HeyTFox - Posts: 21 |
Hello SC, I have two separate Volume Profiles, 1 for the overnight session and 1 for the NY session. I did it this way because I wanted more control of each profile. However, for my NY Session profile, my start time is set to 0830, but it never allows it. It sets itself to 0900. I attached a screenshot with my settings for both session profiles and the chart. Also, not sure why I am now just noticing this, because I had it working before. I did recently update the software, but not sure when this problem started. Thank you for the help. |
Screenshot 2024-04-02 183831.png / V - Attached On 2024-04-02 22:38:47 UTC - Size: 224.77 KB - 20 views Overnight Vol Profile.png / V - Attached On 2024-04-02 22:39:58 UTC - Size: 224.98 KB - 17 views chart pic with profile start times marked with vertical line.png / V - Attached On 2024-04-02 22:45:29 UTC - Size: 467.12 KB - 18 views |
[2024-04-02 23:23:24] |
Just realized something. I had it on the 1hr chart. All other lower timeframes my NY Session profile begins at 0830 per my settings. I would still like my NY Session profile to start at 0830 on all timeframes. Is that possible?
[2024-04-03 00:39:48] |
Sierra_Chart Engineering - Posts: 14315 |
If there is no bar in the chart that starts with 8:30 you cannot start a volume profile at that time.
