Date/Time: Wed, 27 Nov 2024 18:38:49 +0000
Zig Zag Indicator Issue
View Count: 1380
[2014-08-13 06:23:41] |
Pawel_Szpak - Posts: 48 |
Hi, I've got the zig zag indicator set up on a renko chart. Setting the "Reset ZigZag at Start Of Trading Day" to "yes", makes the indicator disappear completely. See attached. One file shows the indicator with that setting at "no" - it shows the volumes/zigzag lines/zigzag length, and one to "yes" - shows nothing. This is the only option I am changing on this indicator. |
ZigzagNoReset.png / V - Attached On 2014-08-13 06:23:20 UTC - Size: 128.17 KB - 373 views ZigZagYesReset.png / V - Attached On 2014-08-13 06:23:27 UTC - Size: 106.92 KB - 397 views |
[2014-08-15 22:06:23] |
To let you know, this has not been overlooked. We just have not had time to get to this yet. We expect to look into this next week.
[2014-08-18 23:30:41] |
Al SC Developer - Posts: 434 |
This function seems to work fine for us. What session start and end times are you using (Chart Settings >> Main Settings)? Also, what time zone are you using (in Data/Trade Service Settings)? |
[2014-08-19 09:59:30] |
Time zone: London (+0GMT/+1BST) Session times 05:59:59 - 23:00:00 - attached screenshot. Currently on version 1173 (if that is relevant) |
Chart settings.png / V - Attached On 2014-08-19 09:58:59 UTC - Size: 68.44 KB - 356 views |
[2014-08-19 14:19:13] |
This will be fixed in ver 1176.
[2014-10-02 07:41:09] |
User96105 - Posts: 113 |
Hi, I am also getting this error. It may be co-incidence but this seems to have started since upgrading to 1157 a few days ago... Failed to get the Advanced Custom Study function address for scsf_MouseMenuExample in SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2014-10-01 21:31:50 |
[2014-10-02 07:46:48] |
This has been resolved. Update Sierra Chart to the latest release with Help >> Download Current Version.
[2014-10-02 07:52:18] |
Okay, I downloaded the non-CLR version a few days ago. I've now updated to 1199 which will presumably fix the problem. Looks like we now have some nice pretty icons! Also no option to download non-CLR. Thanks |
[2014-10-02 08:25:15] |
The non-CLR version is now labeled "New Spreadsheets" on the Help menu.
