Date/Time: Wed, 23 Apr 2025 03:16:02 +0000
[User Discussion] - Error when removing Orderflowlabs anchored vwap
View Count: 579
[2024-04-02 18:34:39]
jmftattoo - Posts: 99
Everytime I attempt to remove the free orderflow labs anchored vwap it is throwing this error -
"Caught an unhandled exception in C_MainMDIWindow::WindowProc. Message:273, wParam:32804, lParam: 0 *"
Then after that the chart is unuseable. data does not back load, I cant add any other studies. I have to open a new chart, and start again with the build. What could be causing this?
[2024-04-02 18:38:46]
after the fact of removing it , It completely wipes the chart , I cant refresh, I cant redownload, I cant add studies, nothing. Its ruining my main workspace.
[2024-04-02 18:51:19]
Sierra_Chart Engineering - Posts: 19307
When you encounter an exception like that, Sierra Chart must be restarted.
We recommend using Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
Date Time Of Last Edit: 2024-04-02 19:57:18
[2024-04-02 18:53:38]
I deleted all of their tools, I have them all built either in ASCIL, or in house studies anyways, not worth the hassle.
[2024-08-07 23:27:58]
XL - Posts: 17
I was considering using their AVWAP (since SC ECI AVWAP resets the anchor points AVWAP resets anchor points ).
Was it any good?
[2024-08-08 06:20:04]
User719512 - Posts: 309
OFL (OrderFlow Labs) fixed that issue above almost immediately after being reported. The studies are free, so no barrier to entry to try them XL.
It's the first and only study on Sierra from a 3rd party (that I have ever seen) that lets you click and drag a study on the chart with your mouse.
[2024-08-08 13:17:02]
XL - Posts: 17
Thank you for the update. I will be looking into it today. Hopefully it doesn't reset the anchor points like the current ECI AVWAP does.
UPDATE: The AVWAP is working great. It is not resetting with reboots like the ECI AVWAP. I actually really like their discord service as well. I highly recommend. So far no issues.
Date Time Of Last Edit: 2024-08-24 19:50:50
[2024-12-13 18:08:52]
Shlomi.B - Posts: 50
Where can i find the order flow labs avwap study ?
[2024-12-13 22:45:10]
Check out https://orderflowlabs.com/pages/ofl-freemium
