Date/Time: Fri, 10 May 2024 07:44:19 +0000
Compact tool value window
View Count: 82
[2024-04-02 16:05:25] |
YAG86 - Posts: 11 |
Hi SC team, my compact tool value window has desapeared and even when I click it off and on it still does not show up, could youu please helpw me figure this out, I already downloaded the latest version and reset the systems, nothing, |
[2024-04-03 01:19:23] |
YAG86 - Posts: 11 |
Nevermind team, I figured this out, by resetting child windows
[2024-04-03 01:48:32] |
Sierra_Chart Engineering - Posts: 14298 |
Yes. Refer to: Chart Drawing Tools: Compact Tool Values Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
