Date/Time: Fri, 10 May 2024 05:27:39 +0000
YM Mini - 15 min frame
View Count: 94
[2024-04-02 15:24:59] |
User660392 - Posts: 31 |
Hi, Since yesterday, mini sized YM , 15 min frame is not accessible to open , why ? TNX |
[2024-04-02 22:56:00] |
Sierra_Chart Engineering - Posts: 14298 |
Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-03 06:59:40] |
HI, The request for image has nothing to do with the solution. After opening daily chart , any attempt to change to 15 min frame can not be done , the program changes it immediately to daily frame. |
[2024-04-03 16:37:32] |
John - SC Support - Posts: 31509 |
In this case, refer to: Unable to Change the Bar Time Period for Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
