Date/Time: Mon, 13 May 2024 05:36:31 +0000
market Depth. Max Levels on Bid/Ask
View Count: 75
[2024-04-01 20:50:55] |
Steve Leon - Posts: 295 |
What is the maximum number of levels that can be visualized when this is set to zero on the chart settings? I am currently seeing data for around 50 ticks on ES on both bid-ask and MBO Thank you |
[2024-04-01 21:15:16] |
John - SC Support - Posts: 31555 |
It depends on the particular symbol, but the most actively traded are set for 1400 levels, and this includes the ES. There are a few settings that can affect this. Refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
