Date/Time: Mon, 16 Sep 2024 19:10:44 +0000
Problems connecting Apex to Sierra Charts
View Count: 250
[2024-04-01 20:36:23] |
User276793 - Posts: 50 |
Hi I am trying to connect Apex to SC. I have read everything i can find and followed the instructions but there is something i am missing because it is still not working. For full disclaimer I am running a separate instance or SC connected to Top Step witch also connects to Rhythmic and it works fine. I have attached a image of my trade service settings. |
2024 04 01 sierra error.PNG / V - Attached On 2024-04-01 20:35:41 UTC - Size: 101.03 KB - 58 views |
[2024-04-01 20:56:13] |
I have attached the message logs
2024 04 01 Sierra error 2.PNG / V - Attached On 2024-04-01 20:55:52 UTC - Size: 297.47 KB - 35 views |
[2024-04-01 21:16:16] |
John - SC Support - Posts: 34450 |
Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-03 20:20:55] |
Hi and thanks you for the information. I found some other documents from Rithmic and a youtube video that explained everything step by step I hope this helps if anyone else has this problem..... How to hook Rithmic and Apex up to Sierra charts https://support.atf.com/hc/en-us/articles/13397375485851-Connection-Guide-for-Rithmic-Using-NinjaTrader-8-1-1-7 https://www.youtube.com/watch?v=V3NhJ2KGbrQ&ab_channel=PriceActionVolumeTrader Date Time Of Last Edit: 2024-04-03 20:21:30
