Date/Time: Mon, 13 May 2024 02:17:21 +0000
How to connect to AMP
View Count: 93
[2024-04-01 19:33:38] |
User701530 - Posts: 9 |
I have a funded AMP account that I want to connect. I selected teton and amp in the data/trade server settings, but there is not where to enter my amp log in credentials.
[2024-04-01 20:08:46] |
John - SC Support - Posts: 31555 |
This is correct. If you are using Teton with AMP, then you do not need to enter any credentials. We take of all of that in the setup on the back-end. If you have not already done so, follow the instructions at the following link to connect to your Teton Order Routing account with AMP: Sierra Chart Teton Futures Order Routing: Setup Instructions Note that you have not setup the Denali Exchange Data Feed in order to get the real-time data. Make sure you do this as well as noted in Step #5 of the above instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
