Date/Time: Mon, 13 May 2024 08:10:16 +0000
Error when trying to connect to Teton
View Count: 96
[2024-04-01 19:07:01] |
oceanzhang - Posts: 3 |
I'm able to establish this connection on one computer, but I want to move my algo to a server. I went through the same steps to connect on my server, but when attempting to connect, I get an error message: Connection error: No trade accounts assigned. I tried disconnecting from my first PC and even uninstalling the Sierra software, but I still can't get the connection to work on my server. |
[2024-04-01 19:58:57] |
John - SC Support - Posts: 31555 |
If you are connecting to the same Teton account and that is working on one computer then it should work on another one. If it is not working on one of the computers, then this would mean that something is not right in the setup on that computer. Please go through the Setup instructions starting at Step #6 at the following link for the computer that is not connecting: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
