Date/Time: Sun, 12 May 2024 21:26:17 +0000
No intraday data with Integrated Standard
View Count: 89
[2024-04-01 15:05:52] |
User346364 - Posts: 14 |
Hi, I am getting the attached error when trying to create a 5min chart of EU6. I thought intraday data was included in the Integrated Standard package? Thanks D. |
Screenshot 2024-03-30 123325.png / V - Attached On 2024-04-01 15:05:23 UTC - Size: 3.75 KB - 26 views |
[2024-04-01 16:38:09] |
John - SC Support - Posts: 31555 |
This is not correct. You do have access to our Delayed Streaming Data, but it looks like you are connected to CQG, therefore you would not be able to get the delayed streaming data. You need to setup and pay for, the exchanges for which you want real-time data. For the CME Group, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
