Date/Time: Wed, 27 Nov 2024 07:41:29 +0000
There was an error with the Save File dialog
View Count: 913
[2014-08-12 22:22:07] |
User021827 - Posts: 174 |
message log reported There was an error with the Save File dialog. Windows error code 0: The operation completed successfully. | 2014-08-12 18:20:36 Is this an error with my system ? Since upgrading sierra, dialog boxes have errors. regards |
[2014-08-13 01:23:48] |
We need to understand under what condition this occurs. Are you pressing the Cancel button one of the Save File dialogs?
[2014-08-13 01:49:53] |
I will report back if it happens again. I do not know the conditions besides clicking cancel. regards |
