Date/Time: Sun, 12 May 2024 16:18:19 +0000
can a single chart have multiple (2-3-4) number bars indicators
View Count: 102
[2024-04-01 00:29:58] |
User335019 - Posts: 3 |
Hello there, I could not manage to use more than one "number bars" on a single chart. When i add second "number bars", simply blank region appears. On the other hand, chatGPT (attached picture) indicates the possibility of multiple number bars on a single chart Could you clarify whether it is possible or not ? Thanks in advance. |
chrome_vJHppAEJr8.jpg / V - Attached On 2024-04-01 00:24:03 UTC - Size: 59.44 KB - 40 views |
[2024-04-01 15:12:14] |
John - SC Support - Posts: 31555 |
Yes, you can have multiple Numbers Bars studies on a chart. You just have to be careful with how you display the information in each version so that you do not have overlapping information that is unreadable (i.e. you can not have one copy that displays "Total Volume" in column 1 and another copy that has "Bid Vol x Ask Vol" for column 1 - they need to be same or not displayed in one). Refer to the following for further information: Numbers Bars: Using Multiple Numbers Bars Studies on the Same Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
