Date/Time: Mon, 13 May 2024 02:36:14 +0000
Volume at Price Threshold Alert v2: Can it be used with Study/Price Overlay
View Count: 142
[2024-03-29 21:24:34] |
User396 - Posts: 51 |
I am unable to use the "Volume at Price Threshold Alert v2" study to overlay on other charts using "Study/Price Overlay". Is this intentional? I am only able to overlay Adjacent Alert Highlight SG49-SG58 but not SG60. Am I making a mistake? Can SG60 be chart drawing instead of overlay study for simplicity? |
[2024-03-31 21:14:30] |
I want to add to the post that I have changed the drawing style for SG60 to a line to overlay it on another chart. However, it is not functioning as expected.
[2024-03-31 21:49:17] |
Sierra_Chart Engineering - Posts: 14326 |
Volume at Price Threshold Alert v2 requires Volume at Price data. Therefore, it can only be used on the main price graph, of the chart it is on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-31 21:49:25
[2024-04-01 14:59:45] |
John - SC Support - Posts: 31555 |
You can overlay the "Volume at Price Threshold Alert V2", just keep in mind that like with any overlay, the values of the subgraphs are the price levels, so if you are putting the data into the main region, the price points need to be similar. SG60 is is to define the colors and widths of the extension lines. It is not the extension lines themselves. But the Study/Price Overlay does have support overlaying these by setting the Input for "Copy Extension Lines from Source Chart" to "Yes". Refer to the following: Study/Price Overlay Study: Copy Extension Lines from Source Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
