Date/Time: Mon, 25 Nov 2024 05:54:45 +0000
Different data for same ticker with _mbo
View Count: 261
[2024-03-29 20:36:55] |
Filip Urban - Posts: 1 |
Hello. I have a problem when I am not sure wchich ticker to use to show accurate data for my footprint chart. If I use for exapmle tsla and tsla_mbo it shows very different data about volume and its shown on the pictures. Column 2, grey area is total volume.Column 3 red/blue is volume delta. I dont know why the data is different but I would like to know which would be more accurate to actual data. Or is there any more variations to ticker which would be best suitable for the footprint? TSLA_MBO: https://www.sierrachart.com/image.php?Image=1711744396468.png TSLA: https://www.sierrachart.com/image.php?Image=1711744445635.png |
Snímka obrazovky 2024-03-29 212000.png / V - Attached On 2024-03-29 20:20:42 UTC - Size: 282.39 KB - 50 views Snímka obrazovky 2024-03-29 211929.png / V - Attached On 2024-03-29 20:21:01 UTC - Size: 280.92 KB - 53 views |
[2024-03-30 02:34:22] |
Sierra_Chart Engineering - Posts: 17169 |
Those two symbols will give you identical data for the chart bars. Is this in the same installation of Sierra Chart? Do this for each of the symbols: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
