Date/Time: Mon, 25 Nov 2024 05:26:11 +0000
[User Discussion] - Developer Request - Order Entry Study/Program Needed
View Count: 239
[2024-03-29 20:25:58] |
User9415867 - Posts: 38 |
I am looking for a developer that can make an order entry study/program that can toggle on/off and do similar to the picture attached. If that didn't attach correctly, below are the directions -When price crosses a certain line a standing buy or sell stop sits 1 tick outside of the current bar. Once the bar completes, the order is resting 1 tick above or below the bar depending on direction. The stop is above or below that bar depending on direction. |
rangeproject.png / V - Attached On 2024-03-29 20:23:16 UTC - Size: 38.75 KB - 81 views Attachment Deleted. |
[2024-03-30 15:02:59] |
j4ytr4der_ - Posts: 938 |
I should be able to help you with this. Send me a DM to discuss.
[2024-03-30 21:32:47] |
I got your DM but am not able to respond until you approve my request to DM you.
