Date/Time: Mon, 25 Nov 2024 05:13:13 +0000
How do I hide the continuation lines of a study between trading days
View Count: 215
[2024-03-29 16:07:50] |
User763335 - Posts: 82 |
Hi I have a study that plots previous days high/lows, that works fine. But it also plots continuation lines between the sessions, which I'd like to hide. These continuation lines sometimes hides the current day's bars wicks, which is undesirable. pls see the attached screenshot. Pls advise, thanks |
2024-03-29_11-56-47.bmp - Attached On 2024-03-29 16:07:34 UTC - Size: 340.06 KB - 189 views |
[2024-03-29 19:03:17] |
Change the "Draw Style" for the subgraphs in the study where you do not want to show the connecting lines to "Dash". Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-29 20:18:06] |
That worked,thanks
