Date/Time: Mon, 25 Nov 2024 05:14:00 +0000
Multiple Time Frame Indicator
View Count: 298
[2024-03-29 14:55:11]
alexo2022 - Posts: 47
I'm looking for a way or a indicator that will show the current bar status ( if it's green or red ) in different time frames,
for example, daily, hourly, 15 min, 5 min etc.
the purpose of this indicator is to show time frame continuity.
also I attached example for what I mean.
imagemtf.JPG / V - Attached On 2024-03-29 14:54:11 UTC - Size: 15.95 KB - 101 views
[2024-03-29 18:54:16]
Unfortunately, there is not a built-in way to do this.
It can be fairly easily done with a Custom Study where you add a Text Tool drawing to the screen for each item you want, but you have to be able to code it, or pay for someone to do it. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
List of Third Party Sierra Chart Study and System Programmers
