Date/Time: Mon, 21 Apr 2025 13:11:37 +0000
Add or Increase Bid Ask Levels / Rows in DOM Graph
View Count: 443
[2024-03-28 16:17:53] |
Le Dharma - Posts: 82 |
Hey Sierra, I'm looking to increase the visible Liquidity Levels, above and below, the NBBO. Right now, I'm using Teton and Denali. Right now, I can see 25 handles, or 100 ticks, above and below the the NBBO. How do I expand the visible Bid Ask Depth data, to include more price levels? |
[2024-03-28 17:52:41] |
John - SC Support - Posts: 39362 |
Refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels But this might be a limitation on the particular instrument you are viewing. What is the symbol of the chart where you are seeing this limitation? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-29 02:21:41] |
Thanks John - I do believe this worked. I'll know for sure when the market opens. " If using a Sierra Chart provided Data Feed (example: Denali Exchange Data Feed), then select Global Settings >> Sierra Chart Server Settings. Set Max Depth Levels to 0 to receive all the Market Depth levels available, or set it to the number of Market Depth levels required to be received from the server. " |
[2025-02-24 20:12:09] |
lservin29 - Posts: 67 |
In attached image, if bid ask is at 6028s and I want to see more levels of MBO and LOB further below and above. I want to see what is resting MBO at 5975s....how do I increase the levels to show above and below the in pricee action spread - bid ask
[2025-02-25 15:26:05] |
Refer to Post #2 above.
