Date/Time: Mon, 25 Nov 2024 05:31:31 +0000
maximum Sierra Charts installation on a single computer machine
View Count: 318
[2024-03-28 16:12:36] |
mbarbhaya - Posts: 37 |
Hi , Please advise me How many maximum Sierra Charts installation on a single computer machine is allowed ? That information will help me to identify on how many maximum broker / prop-firm connections I can make on one computer. I tried with 3 and it connects , but when a 4th connection is added, one fails , at-a-time only three works , even-if I have multiple installations of Sierra Charts on a single machine. Please advise if there is any configuration change that I need to do on Sierra Charts configurations Thank you |
[2024-03-28 17:50:50] |
There are two different rules that you need to understand. The first is that there is no limitation on the number of Sierra Chart installations you can have on a single machine. The second is that you can only get the Denali data to 3 different installations on a single machine at a time. And you can only have 2 different computers accessing the data at the same time, and you have to pay an second set of exchange fees for this. Refer to the following: Denali Exchange Data Feed: Connections If you are not using the Sierra Chart data for some of these installations, then you can set the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "No". Then select OK to close that window and then select "File >> Reconnect". This installation will then be getting the data from the connected trading service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-28 17:57:51] |
Thank you John for sharing that information. I dont have multiple computers , I work on one computer machine with 2 installations of Sierra Chart. In future if-needed to work with multiple broker, then I will go-with your advise. Thank you |
