Date/Time: Mon, 25 Nov 2024 05:46:38 +0000
Alert for Bid and Ask volume
View Count: 271
[2024-03-28 15:33:58] |
ssangha84 - Posts: 122 |
Hello, I was wondering if there is any way to create an alert to go off if a number of bid or ask volumes are under 10 in a row? Like for example, the number bar screen shot I am posting, the red highlighted area has a lot of ask volumes under 10 in a row. Is there any way I can create an alert for when that happens?
AlertQuestion.jpg / V - Attached On 2024-03-28 15:33:21 UTC - Size: 394.74 KB - 87 views |
[2024-03-28 15:43:32] |
There really is not a way to do what you want without creating a custom study. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-28 16:25:06] |
Is there a page where I can see all code abbreviations for making custom studies? For example, volume is V, high is H, etc. Is there a page where I can see all of these?
[2024-03-28 17:54:44] |
The shorthand items like V for Volume, H for High is for Alerts. Refer to the following: Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables A custom study does not have such a thing, as you are creating the variables you will use. For the list of Variables and Functions available for a custom study, refer to the following: ACSIL Interface Members - Variables and Arrays https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
