Date/Time: Mon, 13 May 2024 00:35:56 +0000
Audio Alerts
View Count: 119
[2024-03-28 14:58:53] |
User360283 - Posts: 440 |
Request that Audio Alerts have a REPEAT function allowing a sound to be repeated 2-10 times Thanks |
[2024-03-28 15:31:49] |
John - SC Support - Posts: 31555 |
This already exists. Refer to the following: General Settings Window: Number of Times to Play This Alert (Global Settings >> General Settings >> Alerts >> Alert Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-28 17:26:00] |
The number of times to play he alert sound should be an option on the Study Alert
[2024-04-01 20:28:02] |
Why are you so resistant to improvements Putting the Number of Times to Play an Art Sound on the Indicator would very helpful instead f messing around with the sous files. Think anbut it!
[2024-04-01 21:10:40] |
We are not "resistant to improvements". We simply have more than enough work to keep us busy. We note all requests, but we can't say when we will get to any particular item.
