Date/Time: Mon, 25 Nov 2024 05:23:20 +0000
Chart Drawing Properties
View Count: 242
[2024-03-27 17:12:29]
User986474 - Posts: 26
I do not like the change that was made to "Chart Drawing Properties" in version 2621. For a line drawing, for example, it use to be the line value and all other properties on different tabs in the same window. This made making changes to the line value and color, etc., very convenient. Now it's not as easy and simple.
Can you revert back to the previous way "Chart Drawing Properties" was set up???
[2024-03-27 17:57:56]
This will not happen. We are slowly removing all dependency on Microsoft Windows, and this is one more step in that process.
Also, the exact same information is available in the new window. We know it can take some time to get used to, but you should not have any issue with regards to items from the old interface to the new one. You should have the same accessibility. If something is not correct in this respect, then let us know.
