Date/Time: Mon, 25 Nov 2024 05:38:49 +0000
Fix Drawings on All Charts
View Count: 174
[2024-03-27 14:16:54]
gambotage - Posts: 16
Hi guys,
Can you fix the drawing issue you've had for many years on the platform? It seems benign to say the least that after many years these things continue to bounce around charts like they do. Or if Lock is needed to actual hold a drawing still, is there an AutoLock Drawings feature? Thanks
[2024-03-27 15:27:26]
What issue are you referring to?
If drawings move, then that implies that the location where you have drawn them is volatile (such as the forward projection area). Refer to the following if this is what you are referring to:
Lines/Rays or Other Chart Drawings Move After Drawing Them
If it is something else, then we need more information.
