Date/Time: Mon, 25 Nov 2024 05:19:57 +0000
Region Data Line Chg on TPO Chart
View Count: 256
[2024-03-27 13:30:12] |
User302605 - Posts: 25 |
The (RC)Bar Price Change (Chg) is enabled on the Region Data Line on a TPO chart. It always shows 0.00 and never changes. The (RC)Daily Price Change (DChg) works just fine on the same chart. Any ideas why the Chg is not working?
[2024-03-27 15:24:58] |
The TPO Chart is special and does not have bars. Therefore the concept of a Bar Change does not exist with a TPO chart, so the value is always going to be 0.00.
[2024-03-27 15:32:35] |
Hi John, thank you for your quick reply. I appreciate it. That makes sense. Take care!
