Date/Time: Thu, 19 Sep 2024 16:15:51 +0000
ZigZag with Volume
View Count: 1027
[2014-08-12 18:33:14] |
User96267 - Posts: 43 |
Dear SC-Community, is there a ZigZag indicator which also shows the traded volume on each ZigZag? Thanks for any help! Max |
[2014-08-13 04:28:41] |
This is supported with the Zig Zag study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s133 Refer to the Display Zig Zag Volume Study Input. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-13 07:12:44] |
I imported this, but the Volume says "0" on every ZigZag. Maybe I did something wrong. Thanks for your help. EDIT: Had to set calculate to "Yes" Date Time Of Last Edit: 2014-08-13 07:19:03
[2014-08-13 07:50:21] |
Yes, you need to set to Yes the input to calculate the zigzag volume.
[2014-08-13 07:55:16] |
Thank you very much!
