Date/Time: Mon, 25 Nov 2024 05:12:05 +0000
RTH and Overnight VbP - VPOC and WVAP Connecting Lines
View Count: 233
[2024-03-27 11:20:41] |
User948093 - Posts: 6 |
I'm having trouble removing the VPOC and VWAP connecting lines that run between the end of the RTH (or Overnight) sessions and the start of the next RTH (or Overnight) sessions. Is there a setting that will make the VPOC and WVAP terminate at the end of the session? See attached for an example.
Attachment Deleted. Sierra Chart_VBP_VPOC and WVAP Line Connections.png / V - Attached On 2024-03-27 11:18:42 UTC - Size: 147.85 KB - 55 views |
[2024-03-27 15:14:14] |
Set the "Draw Style" for the subgraph for that item to "Dash" instead of "Line". Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
