Date/Time: Mon, 25 Nov 2024 05:41:01 +0000
Chart Link Scroll Position
View Count: 328
[2024-03-27 07:13:09]
Oz - Posts: 50
I'm trying to get 2 charts to scroll in sync with each.
Same time-frames different filters/studies to compare the two as each scrolls ect.
I've read the info on chart linking and believe I've set up the linking correctly as explained via:
Chart Settings >> Linking >> Chart Link Number on each chart with scroll position to Yes on each chart setting.
Pic attached.
It's not working for me?
What have I missed?
Many thanks.
Cheers
Date Time Of Last Edit: 2024-03-27 11:19:23
imageChart Link Scroll Position1.png / V - Attached On 2024-03-27 07:11:48 UTC - Size: 61.66 KB - 59 views
[2024-03-27 15:07:06]
You have two different link numbers for the chars. One is 29 the other is 26. They need to have the same link number.
[2024-03-28 00:32:46]
Oz - Posts: 50
Ok so what you are saying is chart#26 should show link with #26 and then chart#29 also #26.
This worked thank you.
[2024-03-28 12:40:58]
Yes. The chart numbers have no relationship to the link number, they are completely separate items. The link number defines the actual link between charts, so charts that share the same link number are "linked". Refer to the following:
Chart Settings: Linking
[2024-03-28 16:26:18]
Oz - Posts: 50
Ok thank you, that makes sense now.
