Date/Time: Tue, 15 Sep 2026 15:08:01 +0000
conection not possible
View Count: 1260
[2014-08-12 15:01:48]
User60070 - Posts: 1
hi
i wanted try oec brocker but i can't connect
Software version: 1173 | 2014-08-12 16:47:06
Your usage time has ended. You are in FREE MODE. Features are restricted. | 2014-08-12 16:47:06
To purchase more time select Help>>Purchase on the menu. | 2014-08-12 16:47:06
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-12 16:47:06
Active service: OEC FIX/FAST | 2014-08-12 16:47:06
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-08-12 16:47:06
2014-08-12 16:47:06 Local computer clock time | 2014-08-12 16:47:06
2014-08-12 14:47:06 GMT time | 2014-08-12 16:47:06
2014-08-12 16:47:06 Time zone adjusted time | 2014-08-12 16:47:06
Time difference to server time: 0 seconds. | 2014-08-12 16:47:06
Program path: C:\SierraChart\ | 2014-08-12 16:47:06
Data Files path: C:\SierraChart\Data\ | 2014-08-12 16:47:06
OS Version Number: 6.2 | 2014-08-12 16:47:06
Checking for new symbol settings for oec | 2014-08-12 16:47:06
AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-12 16:47:06
AsyncHTTP2 socket (1092) | Connected. | 2014-08-12 16:47:06
Symbol settings are up-to-date for oec | 2014-08-12 16:47:06
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-12 16:47:11
AsyncHTTP2 socket (1092) | Closed. No error. | 2014-08-12 16:47:16
AsyncHTTP2 socket (1092) | Shutdown and closed. | 2014-08-12 16:47:16
Current selected Data/Trading service: OEC FIX/FAST | 2014-08-12 16:48:25
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-12 16:48:27
t SC
this is the message error where is the problem it is from OEC or SC I WILL open an acount in few week and i want compare some future broker thanx for your plateform perform .
tradingshu
Date Time Of Last Edit: 2014-08-12 16:23:36
[2014-08-12 16:31:23]
Your account has been activated and/or reset.
A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
