Date/Time: Mon, 25 Nov 2024 05:41:41 +0000
[User Discussion] - Market with protection orders
View Count: 241
[2024-03-26 16:42:09] |
GuillaumeJ - Posts: 10 |
Hi, I would like to use Market with protection orders for my ACSIL automated trading system. As stated by the CME order types doc : https://www.cmegroup.com/confluence/display/EPICSANDBOX/Order+Types+for+Futures+and+Options#OrderTypesforFuturesandOptions-MarketOrderwithProtection A market order with a maximum accepted fill or canceled if not filled at desired price. I have the read sierra doc but could not find those order types. How to I setup those orders in ACSIL. Thanks |
[2024-03-26 19:10:03] |
ondafringe - Posts: 286 |
Market-with-Protection isn't an order type. The "protective" aspect is automatically implemented by the exchange. See this thread: Attached stop order turns into stop limit order Date Time Of Last Edit: 2024-03-26 20:45:58
[2024-03-26 23:17:37] |
Sierra_Chart Engineering - Posts: 17169 |
Yes but we think this is automatically implemented.
[2024-03-27 09:44:30] |
Ok thank you, I read the CME doc and indeed it is automatic. So to avoid slippage with market order would it be best with Market-limit orders ? I does not clearly says what happens in case of slippage. The only explanation is about partial fills. I would like to know if the market order is not filled at the desired price, does it become limit order or get slipped like a market order ? |
[2024-03-27 15:11:45] |
You need to ask the exchange about this. We have also set this to a User Discussion, so others may give their opinions on this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
