Date/Time: Mon, 25 Nov 2024 04:29:52 +0000
cant download current vrsion of sierrachart
View Count: 212
[2024-03-26 12:26:46] |
User17586 - Posts: 9 |
hello i am trying to download a new version of sierrachart , currently i have the 2495 version , i tried all the version it does not work it says MD5 for files doe not match and maximmum number of retries encountered refer to log .how do i send you the log? do i just press send log to support and put my account number under the box enter your name thanks for your help |
[2024-03-26 14:15:40] |
Sierra_Chart Engineering - Posts: 17169 |
Use the ZIP installer of Sierra Chart instead: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
