Date/Time: Mon, 25 Nov 2024 05:39:22 +0000
Cash market
View Count: 264
[2024-03-26 09:43:02] |
User266447 - Posts: 253 |
Hello, Could you remind me, for instance, SP500 daily chart or DAX daily chart (not an intra-day chart) is a cash market chart? I do not have access to SC recently, so cannot check it. Also, do you have WIG-20 (Polish index) daily chart? Thank you in advance |
[2024-03-26 23:21:17] |
Sierra_Chart Engineering - Posts: 17169 |
Yes Sierra Chart has the symbols. The S&P 500 is $INX. We have to check on the DAX. We have added 10 days of Usage time for your account. Install Sierra Chart and then you can check the symbols: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-27 08:11:37] |
Thank you, but could you turn my access down, please? I will come back to you in the middle of April and ask for the 10-day access then. Thank you in advance. |
[2024-03-27 15:10:45] |
We have removed the added time. When you are ready to use it, please post in the "Account Support Tickets" and remind us that you had asked to use this later. You can access the Account Support Tickets at the following link: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
