Date/Time: Mon, 25 Nov 2024 05:21:24 +0000
[User Discussion] - Delta Stats : NQTV Vs. CME
View Count: 237
[2024-03-26 04:17:52] |
User509533 - Posts: 57 |
I'd like to ensure my understanding is correct since I often find it challenging to interpret delta-related statistics (such as Numbers Bars and Numbers Bars Calculated Values 2) for TLT-NQTV in the same manner as I do for ES_FUT_CME. It appears that those stats for TLT-NQTV indicates aggressive selling when, in reality, there is aggressive buying, and the opposite seems to be true as well. Could there be differences in the DOM, bid, and ask data or calculations between TLT-NQTV and ES_FUT_CME? Thanks! |
[2024-03-26 20:57:11] |
Sierra_Chart Engineering - Posts: 17169 |
We will leave this as a user discussion. There are differences with Bid Volume and Ask Volume between futures and stocks. What the reason for this is, is not within the scope of our support.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-26 20:57:28
