Date/Time: Mon, 25 Nov 2024 04:28:58 +0000
Trade Activity Log
View Count: 272
[2024-03-25 15:41:55]
User472997 - Posts: 9
Hi.
I recently updated to the newest version, 2619 64-bit, revision 49631.
I noticed the Trade Activity Log has been updated.
I really missed the previous design, where the display setting is on the top section, rather than having to click the new "DisplaySettings".
Is there a way to change it back to the previous design?
Thank you.
[2024-03-25 17:03:19]
Tony - Posts: 518
I agree, I found the previous design is way faster for me to change settings.
[2024-03-25 20:09:04]
Sierra_Chart Engineering - Posts: 17169
These changes are to support the move away from MFC in Sierra Chart which is critical task for us.
There were problems with the old interface. Sometimes settings you would set actually were not getting applied. This must have been a problem at the operating system level.
There is also more functionality that can be implemented this way with settings because there is only so much room at the top where the controls were previously. That was always an ongoing issue.
What we will do is put a display on the title bar of the currently set settings. So you can visually see how the controls are actually set in a compact way.
And also the settings window can be continuously open. And resized and moved off to a corner or the side.
