Date/Time: Mon, 25 Nov 2024 05:01:50 +0000
pending modify
View Count: 309
[2024-03-25 11:52:12] |
User774886 - Posts: 2 |
Bonjour j ai sur mon carnet d ordre des entrées d ordre comme si je tradais mais elles ne sont pas actives ça M affiche B/stop/pending modify/0/1 and S/lmt /pending modify/0/1 how to cancel this ..... i reconnect , not cancel, I disconnect , not cancel ... I dont know how to cancel it Best regards Sandra |
[2024-03-25 14:09:25] |
We do not know what the problem may be. Be sure to contact your broker to ensure that the order is where you want it. Then try to reconnect again to CQG and see if everything updates properly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
