Date/Time: Mon, 25 Nov 2024 05:14:20 +0000
Spread Order Entry not functioning
View Count: 238
[2024-03-25 01:20:57]
User519541 - Posts: 5
Have tried the Spread Order Entry and I am unable to get it to function. I'm clearly missing something. Attached is an imagine of my results. In short, whatever spread data has been entered, it does not generate a Spread Price as indicated in attached .png file. Can't even get it to generate data for an exchange listed calendar spread.
Added image, hope it helps.
Using Denali/Teton
Any and all help is welcomed! Thanks
Steve
imageSpread Doc-1.png / V - Attached On 2024-03-25 01:19:27 UTC - Size: 340.9 KB - 55 views
[2024-03-25 01:34:00]
Sierra_Chart Engineering - Posts: 17169
You need to enter the complete symbols like this:
MYMM24_FUT_CME
Date Time Of Last Edit: 2024-03-25 01:34:14
[2024-03-25 09:05:44]
Tried that previously, and just again...
This last time (5 minutes ago) I did get error to activate Auto Trading, that worked, once.
Removed study to enter it again, and now same original result, nothing.
Thanks,
[2024-03-25 13:59:27]
In your original image the study was "Disabled". In this state, you are not going to get any information. You need to enable the study to get the information flowing.
[2024-03-27 13:39:04]
Actually discovered issue, for any others than come across this...
My symbols were not on the same exchange...
They NEED to be from same exchange.....
*palm to face*
Working GREAT now
