Date/Time: Mon, 25 Nov 2024 04:31:30 +0000
Using bracket orders and Buy exit and Sell exit columns
View Count: 275
[2024-03-24 17:27:40] |
aswade3451 - Posts: 19 |
I was wondering if it was possible to use the chart trader window for take profits and stop losses and combining it with using the buy exit and sell exit columns. For example I would like a 16T take profit, but if certain conditions take place it closes the trade early. Thanks! |
[2024-03-25 13:18:48] |
If you have not defined specific Stop/Target items in the Spreadsheet System for Trading, then the system will use what is set in the Trade Window. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Attached Order Target Offset (write only) [J80] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-25 15:59:15] |
Sierra_Chart Engineering - Posts: 17169 |
Yes you can do this. Also refer to: Spreadsheet Systems, Alerts and Automated Trading: Initiating Trades with Auto-Trading and Using Manual or Attached Orders Exits Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
