Date/Time: Mon, 25 Nov 2024 05:46:55 +0000
cumulative delta studies does not show data
View Count: 225
[2024-03-24 13:11:53]
User721265 - Posts: 6
hi ,
For the Friday march 22 session , the cumulative delta was not showing any data as well as the footprint ( please see attachment ) . I have circled the area where we should be seeing market orders... thank you for your help
imageScreenshot 2024-03-24 at 9.02.03 AM.png / V - Attached On 2024-03-24 13:10:09 UTC - Size: 188.33 KB - 56 views
imageScreenshot 2024-03-24 at 9.05.31 AM.png / V - Attached On 2024-03-24 13:10:15 UTC - Size: 153.14 KB - 56 views
[2024-03-24 18:46:02]
What is the symbol for those charts?
And what is your setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" set to?
[2024-03-24 23:29:38]
mY setting for ' DATA TRADE SERVICE SETTING " >> COMMON SETTING IS SET >> ALLOW SUPPORT FOR SIERRE CHARTE DATA FEED ...is set to YES . They Symbol is the EMI S&P .. I realized I did not download the current version . Hopefully it will be fixed by tomorrow . The symbol is the EMINI S&P .. thank you
imageScreenshot 2024-03-24 at 7.27.33 PM.png / V - Attached On 2024-03-24 23:29:00 UTC - Size: 139 KB - 53 views
[2024-03-24 23:47:57]
Sierra_Chart Engineering - Posts: 17169
Fully re-download the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Only use this command from the Edit menu at the top of the main window or chart.
Or, in the case of a Continuous Futures Contract chart, follow these instructions:
After about a minute provide a copy of the Message Log following these instructions:
