Date/Time: Mon, 25 Nov 2024 05:39:56 +0000
New SC GUI - Tool Configuration Name can no longer be changed back to empty ... ?
View Count: 280
[2024-03-23 15:08:06]
@sstfrederik - Posts: 404
Some of the Drawing Tools configuration have the new GUI. It seems that the Tool Configuration Name can no longer be empty after it has been assigned a name.
To replicate:
- take a Line Config window (New GUI). Set a TC Name, save. Go back to the tool config window and try to remove the name and save. Not doing it.
- take a Retracement config window. Do the same as above and that will work.
Can this be resolved or is this something new?
Thanks.
Fred
[2024-03-23 19:27:48]
Sierra_Chart Engineering - Posts: 17169
Yes we will resolve this.
