Date/Time: Mon, 25 Nov 2024 05:16:30 +0000
Some Settings are in Read Only Mode
View Count: 397
[2024-03-23 03:13:28]
Lorne McConnachie - Posts: 8
Hey
Hope all is good
Sooo, I have been running the market depth historical graph with renko bars with wicks
I have been looking to amend the number of ticks that are required to create a new bar
However, since amending some settings, several features within chart settings are now marked as "read-only" - this is across the board if i create a new chartbook and go through symbol > create new intraday chart
Please see the attached screenshots.
I am not running multiple instances just for context
Please advise, if you would require any further details to troubleshoot, please let me know
Many thanks,
imageread only 2.PNG / V - Attached On 2024-03-23 03:11:55 UTC - Size: 11.52 KB - 61 views
imageread only 1.PNG / V - Attached On 2024-03-23 03:12:14 UTC - Size: 156.9 KB - 57 views
[2024-03-23 09:49:57]
Sierra_Chart Engineering - Posts: 17169
A read-only setting, means that it is not applicable in the current context. For example, if the DOM Graph is not enabled, all of those settings for it will be read-only.
[2024-03-23 09:58:10]
Thank you for your quick response
When in chart > chart settings > Bar Period
Renko Bar New Bar Mode:New Trend Bar When Range Exceeded | New Bar When Open Crossed = This is set to read-only, and cannot be amended
Even when i create a new chartbook and open a new intraday chart
Many thanks,
[2024-03-23 10:09:48]
You should expect it is read-only, when the Bar Period Type for the chart is not set to a Renko type.
[2024-03-23 11:36:27]
Can you please advise how I set it to Renko type and how to resolve it?
I was able to amend the tick configuration when creating a new bar prior, but now there is no option to change
Thank you
[2024-03-24 14:47:17]
Change the "Chart >> Chart Settings >> Bar Period >> Bar Period Type" to on of the Renko options (whichever one you want to use) and then set the "Bar Period Value" to be what you want. Refer to the following:
Chart Settings: Bar Period Type (List) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu)
In the image you provided, your Bar Period Type is set to "Days-Minutes-Seconds-Milliseconds per Bar".
[2024-03-24 17:24:33]
Thanks John
I have been a potato here
Appreciate your patience
Have a great day :)
