Date/Time: Mon, 25 Nov 2024 05:48:39 +0000
web-based platform
View Count: 670
[2024-03-22 00:05:09] |
User955491 - Posts: 3 |
Is there a web based platform to login into and check positions and place trades? If so what are all of its features?
[2024-03-22 01:17:11] |
cmet - Posts: 551 |
Account Control Panel > Web Trade Account Data and Order Entry
[2024-03-22 07:27:43] |
Max0618 - Posts: 11 |
Has the web version been optimized for smartphones? I'm just interested in a nice big flatten all button, nothing else |
[2024-03-22 15:01:49] |
The Web-based trading panel is only available for the Teton Order Routing Service, or if you are using one of our "Simulated Futures Trading Services". It has not been "optimized" for phones, it is just a way to access the information through a browser. But you can Flatten positions from it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 23:57:49] |
You can place trades from the web-based trading panel then? Does it show market data?
[2024-03-23 21:43:14] |
Sierra_Chart Engineering - Posts: 17169 |
It does have a different view for mobile devices. This is the latest version of the trade panel: https://apps.sierrachart.com/tradepanel/ This new version should be considered, as still under development and not finalized. It is not certified for production release yet. Both the old and the new version support market data, but the new version is better because it also supports real-time market data instead of only delayed data. However important warning about the real-time market data, it will interfere with the Sierra Chart desktop program. You cannot use real-time data on both at the same time. That is why we recommend using delayed data on the trade panel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-23 21:44:03
[2024-03-24 07:09:49] |
User61168 - Posts: 403 |
You cannot use real-time data on both at the same time. - Is it possible to eliminate this limitation if we agree to pay for two real time data feeds (one for SC platform and one for webpanel?
[2024-03-24 23:46:39] |
Yes, you can pay 2 exchange fees to solve the problem.
