Date/Time: Sat, 21 Sep 2024 00:53:33 +0000
Spreadsheet for trading not triggering
View Count: 170
[2024-03-22 00:03:21] |
User484096 - Posts: 12 |
I set up a simple trail by 3 bars exit to test it in sims. The exit column turned 1 but it is not exiting the trade. It should exit the position when price move about 18614.50. Send to trade service: No Sim: On Auto Trade: On Please see screenshot. |
SimsNotWorking.png / V - Attached On 2024-03-21 23:58:19 UTC - Size: 392.73 KB - 35 views |
[2024-03-22 14:07:05] |
John - SC Support - Posts: 34605 |
Open your "Trade >> Trade Service Log" and see what it shows for why the order is not going through. Our guess is that since you are trying to do a "Sell Entry" rather than a "Buy Exit" that the problem is that you do not have the Input for "Allow Entry with Working Orders" set to "Yes". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
