Date/Time: Sun, 28 Apr 2024 03:45:29 +0000
Telegram alerts: chart images not sending for order fills w/ alert
View Count: 113
[2024-03-21 20:24:45] |
mattvk - Posts: 32 |
Telegram text alerts are working as expected, and "Capture Chart Image on Alert for Chart" is set to "Yes". I have "Alert 1" set for both order fills and also some chart drawing alerts. Chart images are being sent via Telegram for the chart drawing alerts but not for order fills using the same alert #. v_2621 |
[2024-03-21 20:53:57] |
Sierra_Chart Engineering - Posts: 14111 |
Yes this is true. We can add support to also send a chart image for order fills. We will work on that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-21 20:54:10
