Date/Time: Wed, 27 Nov 2024 07:44:36 +0000
Did Some Study Functions Change In 1173?
View Count: 1218
[2014-08-11 23:06:39] |
cmet - Posts: 552 |
I just upgraded to 1173. I have a very fast chart where I plot my intraday levels and then use that to overlay onto my trading charts. All of the studies that I use are from the SC Studies list. However, for that chart I now get this error: Chart: ESU4-CME 30 Sec #2 | Study: Unknown name | Exception occurred while calling study function. | 2014-08-11 16:01:38 Here are the studies I am using: http://postimg.org/image/u5h6wktql/ My question is if anything was changed on these in the new version. I do not get this error with 1157. Date Time Of Last Edit: 2014-08-11 23:07:03
[2014-08-12 00:24:31] |
There have been no changes to those studies. For us to determine what the problem is, we need to get your Chartbook. You can privately attach it by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Another thing you can do is remove one study at a time from the #2 chart until that error goes away and that will determine which particular study is causing the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 00:25:22
