Date/Time: Mon, 25 Nov 2024 06:27:11 +0000
Pull-back bid/ask volume data tool available?
View Count: 230
[2024-03-21 17:41:27] |
DP - Posts: 4 |
Hello, Is there a way to setup a pull-back data footprint tool that continuously resets the bid/ask volume after the market moves a certain number of ticks away from price (e.g. 3 ticks). I am trying to see the freshest volume at bid/ask when the market returns to a price after moving away from it. It seems I can only see cumulative volume on a footprint while a bar is forming. Thanks. |
[2024-03-21 18:30:32] |
Refer to the following to see if this is what you are looking for: Numbers Bars: Pullback Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
