Date/Time: Mon, 25 Nov 2024 07:00:15 +0000
[User Discussion] - Auto Volume Profile Drawing
View Count: 227
[2024-03-21 17:30:23] |
DP - Posts: 4 |
Hello, Can Sierra Chart be setup to automatically draw draw volume profiles for market swings on a range chart? (e.g. new profiles drawn for each swing of the zigzag tool so it draws a new profile every time a new swing occurs)? |
[2024-03-21 18:28:26] |
You would have to create a custom study to do this. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
