Date/Time: Wed, 23 Sep 2026 02:03:23 +0000
Think or Swim Data Connection
View Count: 3105
| [2014-08-11 23:01:44] |
| User28366 - Posts: 14 |
I am trying to use my TOS account connection to provide live data for Sierra. I have followed all the directions; however, the window reads 'Not Connected'. When I check the message log it says 'your current service package does not support this function'. I selected service package 3; does this not support using TOS as my data provider?
| [2014-08-12 00:28:07] |
You need to restart Sierra Chart after the payment for package 3. Here are the TD Ameritrade/Think or Swim set up instructions: http://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 00:28:29
| [2014-08-12 20:42:37] |
Do you know if TOS provides tick by tick data and historical data through this connection?
| [2014-08-12 22:28:15] |
On the TD Ameritrade connection that Sierra Chart supports, there is no futures data. Did you need futures or stock data? In any case, you can use the Sierra Chart Real-time and Historical Exchange Data Feed with your Think or Swim account: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 22:29:19
| [2014-08-22 04:55:58] |
| Bedhog - Posts: 187 |
Is it possible to use the SC Data Feed to get futures data and have futures orders filled at TDA using a single instance of SC?
Date Time Of Last Edit: 2014-08-22 04:56:24
| [2014-08-22 05:06:04] |
The connection that Sierra Chart has to TD Ameritrade does not support futures. You can certainly use the Sierra Chart Exchange Data Feed with your TD Ameritrade account for futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
